Rear Shocks Air Suspension + 3rd Row
Old Feb 6, 2024 | 08:39 PM
RyanLR3's Avatar
Default Rear Shocks Air Suspension + 3rd Row
Replaced rear shocks on 2017 with air suspension and 3rd row. Couldn't find any reference online to interior parts to remove so I'm just sharing mine. All that needs to be removed is
Rh rear cargo area trim circled in red
Lh and rh 3rd row cup holders. They just pull up to remove
3rd row seat cushions. Pull up on front of cushion then pull forward
Trim under the third row seats. Just pull towards front of the car
pull carpet forward to expose shock mounts
Remove foam covers over the shock mounts
The shock removal is the same as what these poor range Rover owners detail in the video below.
https://youtu.be/kAZTrvE-Tns?feature=shared
Old Feb 6, 2024 | 08:41 PM
RyanLR3's Avatar
More picks of the shocks disassembled. Very straight forward.
Old Feb 6, 2024 | 10:15 PM
adam5's Avatar
dang that's quite impressive; good job OP and thank you for sharing
Old Feb 7, 2024 | 12:36 PM
JAlley80's Avatar
Great write up!
What shocks did you use to replace?
Old Feb 7, 2024 | 12:41 PM
RyanLR3's Avatar
Thank you
Just stock performance Bilstiens
Old Feb 7, 2024 | 12:56 PM
JAlley80's Avatar
That seems to be the only option.
What prompted the replacement? Time? Miles? Just because?
Old Feb 7, 2024 | 02:41 PM
RyanLR3's Avatar
There wasn't sufficient dampening on the rebound (extension). Especially bad at highway speeds over larger undulations in the road. Suspension would unload too fast making for bouncy/unstable ride. I tow a fair amount as well. Discovery has ~105k miles
Old Apr 28, 2026 | 08:45 PM
buzzliteyeh's Avatar
Thanks for this, its made it way easier for me to pull my seats out !!
Old Apr 29, 2026 | 11:29 AM
ar077's Avatar
My 2017 HSE Td6 (with air suspension) doesn't have third row seating so changing the rear shocks is probably much easier than having to deal with the extra row of seats. Anyone know of any "gotchas?"
Old Apr 29, 2026 | 04:30 PM
RyanLR3's Avatar
Not sure, but could be similar to the Range Rover install above, given no 3rd row. Actually is more involved without the 3rd row
Roont
Sep 14, 2023 08:49 PM
Lafogleman
Feb 9, 2023 04:17 PM
sarek
Aug 7, 2022 06:36 AM
pokey
LR4
May 12, 2022 10:30 AM
Cheri-o
Mar 29, 2020 08:28 AM
