New 2001 Disco SE II V8
Old Apr 2, 2013 | 04:14 AM
nateandnikki's Avatar
Default New 2001 Disco SE II V8
Hi all!!!
We are Nathan(nate for short) & Nikki. We are from Ipswich, Queensland, Australia.
We have recently purchased a 2001 V8 series II SE discovery. We have had a couple of small setbacks since purchasing it, but thank god its covered by warranty.... other than that, absolutely LOVE IT
See you around guys
Old Apr 2, 2013 | 07:28 AM
Welcome. The front propshaft, if oem, is a problem waiting to happen. The U joints don't all have grease nipples, it dries out, the shaft snaps with very little warning, and tries to knock a hole in transmission. Rebuilding (write up in our tech area), or replacing with a fully greasable one, should be high on the list of things to do. You will "discover" that the heat gauge stays at 50% over a very wide range, using a scanner or Ultra Gauge will give you a true picture of coolant temp. Many owners have converted the oem thermostat to a 180F "soft spring" model, lowering engine temps about 10F across the board. The "RAVE" is the factory set of shop, electrical, and owner manuals; free download link below.
discodancedisco
Feb 2, 2011 10:46 AM
johnkbl
Jan 19, 2010 05:22 AM
sharp
Jan 9, 2010 07:03 PM
flip3076
Sep 2, 2009 03:22 PM
TREX_Star
Dec 6, 2007 10:27 AM
