ticking sound
Old Jul 30, 2017 | 05:02 PM
rbrouillette81's Avatar
Default ticking sound
i just had some repairs done to my rover ( coils, wires, valve cover) i had p0306 misfire problem and ticking noise. now misfire is ok but ticking sound still at it. my mechanic told me we still need to replace front cranckshaft seal to get rid of ticking sound. im not sure if it will. the last job costed 1500. dis any of you have the same issue and how did you get rid of ticking noise? thank you.
Old Jul 31, 2017 | 04:04 AM
Sixpack577's Avatar
Ticking can be many things.
Lifter(s ), rocker shafts, rocker arm, valve, oil pump, or a slipped cylinder sleeve. Cam, rod, or crank bearings tend to knock, not tick.
If the truck doesn't overheat, odds are it isn't a slipped sleeve.
The crank seal, front or rear will do nothing for any noise.
The oil pump is directly behind the timing cover. Apparently those are common to break in the 4.0/4.6
I just found the outer oil pump gear in my 04, 4.6 broken yesterday. It would not tick until it warmed up.
An oil pump is $75. Lifters are $95.
Neither are hard to replace, and if the truck runs good other than the tick, one of the 2 is likely the problem (although, as said, there are other causes).
If you can't do the work, they're gonna getcha on labor.
And, if the mechanic is telling you a seal is the problem...find another mechanic.
Humdinger
Oct 18, 2016 05:05 PM
john65b
Oct 10, 2013 05:00 PM
marlymarl
Oct 16, 2008 07:21 PM
jwinck
Sep 23, 2008 09:03 AM
mr.47
Mar 27, 2007 02:45 PM
