Key Tip Broke Off in Ignition - Disco 03
Old Aug 8, 2013 | 10:09 AM
SantaCruzRoverGirl's Avatar
Unhappy Key Tip Broke Off in Ignition - Disco 03
I have a new spare key! Can a locksmith fix this issue? Or do I have to have it towed to a Landrover repair shop?
Old Aug 8, 2013 | 01:52 PM
Locksmith should be able to say yes or no. I think yes.
Old Aug 8, 2013 | 02:03 PM
cosmiccharlie's Avatar
Same thing happened to me and a locksmith could not extract the piece that was in the ignition. If you are handy, this is the write up i followed to fix mine.
https://landroverforums.com/forum/di...ock-fix-35422/
Old Aug 8, 2013 | 03:44 PM
BTW, the locksmith that worked on mine screwed up the little "flap" in side the ignition. He was trying to pull it out thinking it was the key piece!! And he still charged me....
Old Aug 8, 2013 | 04:21 PM
Locksmith couldn't get the key tip out, thought it went to the back of the cylinder, had it towed to a Landrover mechanic. Is there a good place to order that key ignition if it needs replacing? Ha! I called the dealership and they quoted $852. and said that part comes from UK and takes 20 days to get! Yikes. PS Sorry I posted to "Off Topic" I'm still new at learning the posting process!
Old Aug 9, 2013 | 07:38 AM
If you have to replace the ignition and don't mind having a second key for your truck, then call Paul Grant, he will have a good guaranteed used set with it's own FOB for a very small amount.
will rocket
Off Topic
Sep 12, 2013 06:23 AM
SantaCruzRoverGirl
Aug 8, 2013 10:56 AM
88Mwife
Oct 31, 2011 05:08 PM
iplayblues4u
Jun 30, 2010 06:02 PM
ropadope
Oct 5, 2007 07:30 AM
