turbo discovery
Old Apr 22, 2016 | 10:51 PM
ttdiscovery's Avatar
Talking turbo discovery
Hey there, what I am wanting to do is turbocharge my 4.0ltr v8 dicovery 2, so what my 2 questions are... What ecu can I use or do I have to go after market, and the second question.... Do I need a better more higher revs camshaft or should the stock 1 handle it... Thank you for any help
Old Apr 23, 2016 | 01:18 AM
Racer X's Avatar
Old Apr 23, 2016 | 01:19 AM
Racer X's Avatar
No, but seriously, do your homework on these engines, and what needs to be done to an engine when you add forced induction into the mix.
There's no quick answer to the question you're asking.
Old Apr 23, 2016 | 02:09 AM
Yeah no worries mate, I haven't seen any at all that a v8 turbo so I thought would try something different.. But cheers and yeah will do my homework..
Old Apr 23, 2016 | 09:01 AM
TOM R's Avatar
There was a guy in Vegas running Volvo turbos , iirc he kept blowing engines and moved on from rovers, I am sure his info is floating around
Old Apr 23, 2016 | 09:06 AM
Shiftonthefly1's Avatar
We are all on crack here. Don't listen to us.
Yea I bought a bunch of parts off of him. He had a pile of grenaded motors as a result. Doesn't seem like a good idea at all.
Old May 10, 2016 | 05:18 PM
OffroadFrance's Avatar
Turbo charging has never been done on the early engines by LR probably for good reasons whereas the later engines are supercharged or turbo charged. Put it this way, I wouldn't want to waste my time fitting a turbo to the 4.0 or 4.6 V8 just to watch it grenade big time.
Old May 11, 2016 | 12:29 AM
Joemamma1954's Avatar
Forced induction, would require you to bullet proof your bottom end, top hat liner the block, install lower compression forged pistons, have the block O-ringed(groove the block for stainless o-rings around each cylinder) Fel-pro makes o-ring head gaskets, but not sure if they make them for LR engines. Cam should be ground for forced induction(don't need a lot of lift or duration). You would also need a better flowing exhaust. Fuel trims, ignition timing would have to be modified. If all this were accomplished, the drive train would not be able to handle the power.
I am sure I left something out.
Old May 11, 2016 | 12:52 PM
I'm with you on this one Joe, and why would anyone want to produce a high speed, high powered super dooper farm truck. Back in the 1980's or maybe it was the 1970's Janspeed produced a twin turbo Range Rover for reasons better known to themselves. , Ferrari, Porche, Aston, whatever but a 4x4 ............ why
Willie00d2
Feb 1, 2013 05:15 PM
skymantra
Nov 20, 2010 06:27 AM
Ed Sinclair
Oct 4, 2008 10:35 PM
viper205
Jun 17, 2008 07:44 PM
dmcmurtrie
Dec 8, 2007 03:46 PM
