Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
RR Evoque TD4 2.2 Coolant leak
Old Dec 9, 2024 | 10:22 AM
Svaggen's Avatar
Default RR Evoque TD4 2.2 Coolant leak
I have a slight coolant leak, about 1 liter per month and i am struggeling to find the reason for the leak. I took off the wheel on passanger car and opened up from there and found the following (Check image).
Is this hose part of the coolant system or is this not where the error is? i really struggle to find the leak. i suspect its just a hose.
dripping from the underside of red hose with the clamp. but also wet on top of the hose. clearly coolant dripping.
the oil
the oil "dirt" you see from here is from an old oil leak i think. Can you tell me what it is connected to?
Old Dec 11, 2024 | 05:09 AM
gmfain's Avatar
That looks like it.
Pressure test it?
2020Defender
Mar 2, 2026 10:05 PM
Invictus
Mar 14, 2022 08:26 AM
meltdowndave
Oct 12, 2017 12:27 PM
Carl082974
Oct 25, 2010 09:28 PM
tom_meeks@yahoo.com
Aug 14, 2008 05:40 PM
