Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
Remove fuel rails on a 5.0?
Old May 29, 2020 | 06:49 PM
AZRR's Avatar
Default Remove fuel rails on a 5.0?
I'm slowly disassembling my 2011 5.0, and moving slowly as I've never worked on this vintage Jag engine before. I'm trying to pull the fuel rail on the right side so I can remove the valve cover. I've disconnected all the fuel lines, including the high pressure lines, as well as the electrical harness. I've removed the four bolts, but the fuel rail won't budge. Is there anything else that would be holding the fuel rail in place?
Old Jun 7, 2020 | 05:07 PM
AZRR's Avatar
I thought I'd better finish this story. I got the fuel rail removed with lots of penetrating oil and using a "flat bar" wrapped in a shop towel as a lever between the fuel rail and the valve cover. Before I started prying, I installed the fuel rail installation guide pins that are part of the special tool kit for this engine, so I wouldn't damage the injectors when pulling on the fuel rail. After the fuel rail was removed, the injectors came out without too much trouble using the slide hammer designed for this purpose. It took me a bit to figure out that the removable clips that locate the injectors on the fuel rail had to be pulled off before the collet of the slide hammer would fit on to the injectors properly.
Old Jun 1, 2022 | 01:04 PM
fijibubba's Avatar
5th Gear
Thank you for posting. I'm trying to get my fuel rails off now as i'm replacing the timing chains. After removing the 4 bolts it wiggles a bit but is definitely on there. Can't seem to get them off. I'll try some PB blaster.
Old Jun 1, 2022 | 02:05 PM
fijibubba's Avatar
5th Gear
So I was able to get mine off with the help of a little PV blaster. The fuel rail—after you remove the four bolts— is just hold held on by the seals on top of the fuel injectors. Putting pressure on the rail with a pry bar and wiggling it was enough to loosen them off of the seals, than the fuel rail came right off. I did what you recommended using a rock shop towel on top of the valve covers and putting a little pressure on with a pry bar. Worked great.
Old Jun 11, 2023 | 03:01 PM
ADerry's Avatar
4th Gear
A little off topic but what did you torque the fuel rail bolts up to on reassembly?
richarddeel
LR4
Jul 23, 2017 08:14 PM
TRIARII
Dec 3, 2016 11:19 PM
dmbenson
Jan 27, 2016 10:59 PM
Toyfare
Dec 8, 2013 08:55 AM
EricTyrrell
Mar 13, 2012 10:19 AM
