Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
Detailed instructions possible video replacing 2017 td6 high pressure fuel pump
Old Jun 18, 2026 | 08:51 PM
drhoda1225's Avatar
Default Detailed instructions possible video replacing 2017 td6 high pressure fuel pump
Detailed instructions possible video replacing 2017 Range Rover Sport td6 diesel high pressure fuel pump
Old Jun 20, 2026 | 05:50 AM
wcc18999's Avatar
Range Rover Sport / L494 2017 User Manual Fuel Charging and Controls
Old Jun 20, 2026 | 05:53 AM
wcc18999's Avatar
FYI, you posted in the L405 forum, and you will likely get better answers if you post in the L494 forum. Also be advised that replacing the high-pressure fuel pump (HPFP) on a 2017 Range Rover Sport TD6 is a major job because the pump is mounted at the rear of the 3.0L TDV6 diesel and driven by a dedicated timing belt. You’ll need access from the top rear of the engine and underneath, plus careful fuel-system cleanliness.
thecashmeister
Range Rover L322 (3rd Gen)
Mar 28, 2025 07:38 AM
peetpete
Feb 25, 2025 09:04 PM
Jessicajess
May 27, 2024 07:40 AM
oliverbaer
Jul 3, 2023 10:07 AM
tjjolle
Sep 3, 2012 09:16 AM
