Detailed instructions possible video replacing 2017 td6 high pressure fuel pump
FYI, you posted in the L405 forum, and you will likely get better answers if you post in the L494 forum. Also be advised that replacing the high-pressure fuel pump (HPFP) on a 2017 Range Rover Sport TD6 is a major job because the pump is mounted at the rear of the 3.0L TDV6 diesel and driven by a dedicated timing belt. You’ll need access from the top rear of the engine and underneath, plus careful fuel-system cleanliness.
oliverbaer
Jul 3, 2023 10:07 AM
