Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
06 4.4 Sport Only start when cold
Old May 23, 2025 | 04:20 PM
DarkRovers's Avatar
8th Gear
Default 06 4.4 Sport Only start when cold
Car will only start when cold. I replaced crankshaft position sensor
changed out both cam shaft position sensors as well
no check engine codes come up
the only code I have is a coolant temp sensor that I need to replace
I go to start it when cold and it starts right up
but if I turn it off then try to turn back on it will just crank and crank at times it will start sputter a bit and turn off
fuel pump?
Anyone deal with this issue?
pburgh
Nov 3, 2021 11:21 PM
raptorial
Feb 29, 2020 02:02 PM
ToddD
Feb 11, 2015 09:44 AM
discoHUSS
Jul 24, 2013 04:27 PM
Woody Reems
Jul 14, 2009 08:30 AM
