Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Shuddering when driving - through steering wheel
Old Jan 29, 2024 | 01:28 PM
STPE's Avatar
New Member
Default Shuddering when driving - through steering wheel
Hi,
I have a 2010 Range Rover Sport 5.0L V8
When I purchased it, it had a shuddering/vibration which I assumed was a wheel balance issue.
We put new tyres on the rear, did a wheel alignment and balance, problem did not go away.
We put new tyres on the front, did a wheel alignment and balance, problem did not go away.
We swapped the wheels front to back and side to side, problem did not go away.
Replaced the bushings in the control arms which some where worn, problem improved but did not go away.
Checked drive shaft bushings - which were ok.
Check the steering column and steering box - ok apparently.
Checked that all wheels were concentric - ok apparently. (I don't trust that shop)
The problem is always there but patently obvious at 60+mph on a flat smooth highway, some days it is indistinguishable, but most days it is horrible.
When I accelerate from standing start and turn the wheel (say to go around a corner from and intersection) there is a rubbing grinding noise and I can feel it through the steering wheel, subtle but it is there.
The shuddering can be felt through the steering, not the body, which leads me to believe the issue is up front somewhere.
Any ideas?
I am taking it to a new wheel alignment/balancing specialist today
Old Apr 20, 2024 | 01:09 PM
Sniperteamdoc's Avatar
Default New Tires
Originally Posted by STPE
Hi,
Any ideas?
I had this same issue in a car I just bought 2013 RRS. I also had the shuttering going uphill especially on turns. I replaced all four tires early this week and the shuttering is gone. I’m assuming the tread depth was off and the car was having issues with that. Hope this helps.
Old Jun 16, 2024 | 08:53 PM
duckboy4x4's Avatar
New Member
Default Any update, did you fixed it?
Hi,
Any ideas?
Hi Mate
Did you ever find the problem and had it repaired? my doing the exact same thing . Thanks!
Fallstaff
Aug 1, 2019 04:42 AM
npach82
Aug 8, 2018 05:12 PM
caroba
May 10, 2017 05:21 PM
bangkuaidiscovery04
Jul 17, 2009 08:50 AM
