Range Rover Velar Talk about the Land Rover Range Rover Velar within.
2024 Velar Dynamic SE 250 Subwoofer location
Old Mar 25, 2025 | 10:02 AM
Puetko's Avatar
Default 2024 Velar Dynamic SE 250 Subwoofer location
Hi looking to add an amp to run a subwoofer set up, where is the sub and is it easy to get to the wires?? Just wondering if I can do this myself, I hate taking my cars in to these hacks that are in too much of a hurry to be careful. I'll be adding an amp with a convertor built in so I just need the sub wires and a good place to mount the amp.. Thanks
Old Apr 30, 2025 | 08:36 AM
CincyRovers's Avatar
Subwoofer is located behind the driver's side rear quarter panel in the cargo area.
Old Jan 6, 2026 | 04:46 PM
Smithers166's Avatar
7th Gear
The sub is above the inner wheel well liner above the left side wheel. The wires should run along the the left side in the cargo area under behind the left trim. You'll have to contend with the active noise cancelling system when adding a subwoofer. Some people have cut a wire on the microphone above the driver. Its the same as the F-pace. I have a whole thread about it on the jaguar forum. Search 2021 and newer active noise cancelling. I wrote a whole thing about all I could find on it. Of some things I want to try or have people try is does it make a difference if the oem subwoofer is unplugged? (Does the system run checks on voltage). There are telemetry devices under the back seat. Will it turn off the ANC with one of them unplugged? Let us know what you try and how it works. If you search the f-pace side of things there are some pictures you can see where the wires go for the subwoofer leads.
landy_ala
Nov 19, 2023 12:14 PM
chriss2s
May 29, 2012 06:51 AM
TenMan1
May 7, 2012 02:22 PM
Photographer2009
Audio/Visual Electronics
Dec 27, 2009 05:01 PM
tomfraser
Mar 2, 2009 03:26 PM
