Series I, II, IIa, III Land Rovers For all Series Land Rovers
Clutch trouble series 3 109
Old Jan 3, 2025 | 02:43 PM
Lvv's Avatar
Lvv
3rd Gear
Default Clutch trouble series 3 109
Hello,
​​​​​​I just bought my first series 3, 109 from 1975.
From Norway army, steering on the left.
I drove a 200km and I had a bad clutch.
First the pedal was very low.
Then on a day I couldn't get it in gear.
There was fluid by the pedal. So changing the cilinder was a no brainer.
I thought I'll do the slave also.
While changing the slave, rod came out
Little did I knew (really new in to cars) it should stay in.(I think) So I think the part:
576723 - clip push rod should be around the rod and clamped on to the release lever.
Is that correct.
I think it's broken, but as you all know there is really No space.
If it should be around the lever, I am afraid I need to disassemble the complete gearbox. Or could you get it around it in an other way?
​​​​​​Or maybe I'm wrong about how it should be installed?
Hope some one can inform me
Old Jan 3, 2025 | 09:18 PM
Harvlr's Avatar
It’s been a while since I had my 2A, but I’m pretty sure you don’t need to remove anything other than the clutch slave cylinder.
Old Jan 4, 2025 | 01:22 AM
Lvv's Avatar
Lvv
3rd Gear
Oke, thank you, but the bracket is needed I think? Or is it possible without? I'm not sure if it is/was in.
Old Jan 16, 2025 | 11:16 PM
Lvv's Avatar
Lvv
3rd Gear
Default Solved
Thank you!
I managed to replace the clip and the rod and reassemble everything. It was a bit tricky, but I managed by sliding a small tube over the rod, bending the clip slightly, and then using the tube to push the clip onto the fork.
Thanks for the reply
Marnus
Dec 16, 2024 08:42 PM
mcmorineg
Jan 11, 2024 12:31 PM
turski
Defender
Sep 4, 2022 06:21 AM
Marnus
Other
Sep 19, 2016 08:00 PM
95RoverLWB
Other
Feb 23, 2015 08:36 PM
