Series I, II, IIa, III Land Rovers For all Series Land Rovers
Loud noise from 2.25 petrol engine (video with sound)
Old Apr 5, 2021 | 01:01 PM
Mudden's Avatar
5th Gear
Question Loud noise from 2.25 petrol engine (video with sound)
Hi. First of all, sorry for any bad spelling. English is not my native language.
I'm a new owner of a Land Rover Series III 109 from 1977 with 2.25 petrol. Have never owned a Land Rover before so my knowledge of these cars is limited.
Has a really unpleasant sound from the engine during cold starts, watch the video link and listen carefully. The noise occurred some day after I did an oil service and with new ignition parts. The sound comes from the front of the engine and is prominent during cold starts and when increasing the RPM of the engine. The engine seems to be very difficult to get really hot but when it finally gets hot-ish the sound disappears. If I drive with the heat on in the car, however, the sound returns even with the "hot" engine.
Video link!
Info:
The oil is newly changed, Kroon Classic 20W-50
New oil filter, new ignition cables, spark plug, battery, distributor cover, breaker points, ignition coil and belt.
The ignition is set to approx. 3 ° BTDC and I can not set it earlier because the vacuum diaphragm on the distributor hits a screw head on the cylinder head. See photos.
Ignition is measured with ignition strobe light, 800RPM idle and without vacuum connected to the carburettor.
95-octane gasoline.
14.1 V voltage across the battery (wondered if the sound could be from the belt)
Follow-up question:
How hot should this engine be? I can put my hand on the radiator cap quite immediately after being out and driving approx. half an hour. Is it too cold?
Pulley marking in front of 3°BTDC @800RPM and no vacuum.
Vacuum diaphragm hitting a bolt head.
Old Apr 8, 2021 | 07:47 AM
Mudden's Avatar
5th Gear
I've found the solution to this problem!
The (very odd) noice was actually from the belt.
It was a brand new belt fitted and the tension was lost shortly after installation, I'm guessing that because the belt was folded in it's shipping packaging and had some sharp fold marks. Usually belt noice comes from old belts and are a lot more "screaming". I'm happy that it wasn't something more serious.
And the distributor could be turned 90° counter clockwise and the cable could move one step clockwise in order to correctly set the timing to 6°BTDC as stated in the Haynes manual.
Old Apr 8, 2021 | 11:40 AM
Harvlr's Avatar
It’s always nice to find an easy fix. Series Land Rovers are pretty forgiving.
Old Apr 17, 2021 | 06:42 PM
The Deputy's Avatar
For English not being your first language...your posts are much easier to read and understand than most English speaking folks here...lol. Plus, you posted in the right forum.
Glad you found the issue and it was a simple repair.
Welcome to the forum, too.
Old Apr 23, 2021 | 03:05 AM
Mudden's Avatar
5th Gear
Thank you @The Deputy
I will introduce myself in the "New Member Introduction" later on.
Juan Barriga
Aug 21, 2020 01:28 PM
Mo6
Mar 20, 2020 05:21 PM
MichiganRover
Jan 21, 2013 12:12 PM
Hare
Dec 1, 2012 06:37 PM
roverboy
Jan 27, 2009 06:37 PM
