Old Sep 18, 2016 | 10:27 PM
  #3401
Joe!'s Avatar
Old Sep 19, 2016 | 07:46 PM
  #3402
thesoundguru's Avatar
Well I actually got to use the Land Rover for what it was intended for today. The wife and I packed up and took my son on his third birthday to a drive in Zoo for a little safari. We had a blast letting the animals poke their heads in to get food and let us pet them. The Rover did great and I was just able to put around mostly just idling. Never got over 200 degrees even on a hot day. The crazy thing was that two Zebras decided to get into it and one of them kicked the passenger side door. Didn't really dent the door just scuffed it but it apparently hit hard enough to break the window regulator. So more work to be done, the part will get here Wednesday. Enjoy the Pics!
Old Sep 21, 2016 | 12:57 PM
  #3403
ThisRoverGuy's Avatar
Awesome pictures. Too bad you didn't get more of a dent:
"How's the dent happen."
"Zebra kicked the door."
You don't need to tell them that it didn't actually happen in Africa.
Old Sep 24, 2016 | 07:25 AM
  #3404
I finally got to work on my 2001 Disco since i got off of work early.
- Vaccuumed out air filer box and inserted Wix #46798 air filter
- Sprayed MAF sensor and contacts with electrical contact cleaner while in idle
- Poured Berryman's B-12 in crankcase, ran in idle for 10 minutes and drained oil
- Added 6 qts of Castrol GTX High Mileage synthetic 10w-40 oil
- installed K&N HP-2004 oil filter
While doing this, I got to crawl under the truck to see what other areas needing repair/replacement and to familiarize myself with other part locations.
I also replaced both of my window washer jets ($38 on ebay) since the plastic was fragile and broke apart from the exteme heat of the engine.
Old Sep 26, 2016 | 01:19 PM
  #3405
Robert Booth's Avatar
Replaced the Purge Valve on my D2 and moved my RTT over to the Classic. I'm taking my D2 off of daily driver duties for a few weeks to take care of some maintenance items. I've owned the truck for 4 years now and it's time to give it a bit of a refresh.
Old Sep 28, 2016 | 07:26 AM
  #3406
Joe!'s Avatar
New set of BFG KO2s put on my refurbished kalahari wheels
Old Sep 28, 2016 | 01:37 PM
  #3407
meat's Avatar
nice. Post pics when they're on please
Finally got the ome 2 inch lift on and got rid of the air bags that have been giving me grief
Old Sep 28, 2016 | 04:40 PM
  #3408
Originally Posted by acamato
here is another option: RovahFarm for all your new Land Rover Parts and Accessories
search for ERR4686B (plug) for $3.49 ea and the o-ring is listed below it.
I am looking at getting these for both differentials but what would be better, the rubber o-ring or the metal crush washer?
Cheers!
Old Sep 29, 2016 | 07:25 AM
  #3409
Joe!'s Avatar
Will do. Hopefully putting them on today (if it's not raining)
Old Sep 29, 2016 | 09:41 AM
  #3410
cosmiccharlie's Avatar
Cheers!
The brass plugs are meant to be used with the rubber o-ring. I don't think a metal crush washer would work.
