99 disco wont start
Old Apr 13, 2012 | 12:34 PM
BIG SEXY's Avatar
Default 99 disco wont start
Just changed engines.Engine will only start when using ether. The fuel pump is working and i have good pressure. I have changed cam shaft and crankshaft sensors and changed the injector rail also. Any Ideas? Thanks for the help!
Old Apr 13, 2012 | 01:12 PM
Immobilization? Remove and bypass alarm spider? Reset inertia switch? Are you a D1 or a D2?
Old Apr 13, 2012 | 02:45 PM
Danny Lee 97 Disco's Avatar
Do you have spark?
Old Apr 13, 2012 | 03:29 PM
pinkytoe69's Avatar
Originally Posted by Danny Lee 97 Disco
Do you have spark?
He must since he says it starts with starter spray.
That would rule out the alarm, right?
Old Apr 13, 2012 | 03:58 PM
If no spark, consider that crank shaft sensor might have been skewed putting back on. Every nut and spacer needs to be in correct order, see attached. MFR (multifunction relay) or a fuse (F7 under hood) perhaps? Ground engine block to (-) battery terminal (maybe loose ground strap)? Injectors may not be getting power (MFR supplies power, ECU switches ground on/off for each injector).
File Type: pdf
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
Drnknmnky13
Jul 5, 2006 06:54 PM
