crankshaft front oil seal
Old 12-02-2005, 10:27 PM
JRdisco1's Avatar
Default crankshaft front oil seal
Does anyone know of anything I should watch out for when replacing the front oil seal? It looks doable in my repair manual, but I just wanted to be aware of any surprises
Old 12-03-2005, 10:19 AM
Hank's Avatar
Default RE: crankshaft front oil seal
Did mine the other day in about 15 minutes....Just remove the belt, (may need to remove the fan??? I have elec fans...), remove the bottom "pully" bolt and use a dead blow hammer to remove. Just pry the old seal out, and be careful when replacing the new one. Make sure it's straight, and you don't kink it....
As cheap as they are, you may as well order two. Reason I say that is, if you mess up the first time, you got a back up. The old one will be distroyed when removed, and without that seal, you can't drive the truck...I 'think' Nathan sells them for about 7.00
bosshogt
06-20-2020 04:06 PM
2Much_DISCO
01-29-2013 08:34 PM
humroot
06-21-2012 10:51 AM
BW_Hunter
06-04-2012 05:52 PM
LeakyDisco
11-25-2011 09:38 PM
Quick Reply: crankshaft front oil seal
