misfire
Old 04-27-2015, 11:08 AM
Celto 4's Avatar
well iguess thats that did the compression test warm on #1&#7 120 still
Old 04-28-2015, 06:48 AM
Celto 4's Avatar
good morning just a quick opinion here....is there any benifit to doing the cooling system pressure check at this point i will have to drive a half hour each way for a test kit i have no evidence of anti freeze in the oil and no overheating when running just the low pressure readings in the left bank thanks for any suggestions
Old 04-28-2015, 09:44 AM
abran's Avatar
Are you still chasing the misfire? Do you feel the misfire, as in the engine running rough? Another member told me about a technique he calls baptizing.
Poor water around all the fuel injectors while the motor is running, if the roughness/misfire goes away you need to replace your injector o rings.
If you have the money, buy a pressure tester on eBay. Around $100.
Old 04-28-2015, 01:16 PM
Celto 4's Avatar
hi yesthank you for your reply almost dont know it at idle only under load and acceleration no vapor in exhaust and oil clean what i came up with as a guess pulling upper manifold question the bracket thats in front of the secondary air passenger side do i have to remove that metal line from the manifold or can i wiggle out
Old 04-28-2015, 01:33 PM
abran's Avatar
Not sure what metal line you are talking about. You should only have to remove the nut/studs from the SAI connections to the manifold.
If you are talking about the throttle cables, yes, unbolt bracket and put to the side.
Old 04-28-2015, 03:54 PM
Celto 4's Avatar
got it double nutted the stud
Old 04-28-2015, 03:58 PM
Celto 4's Avatar
bit out of practice did a lot of engine work in my 20's and imported them a long while back but its coming back im aaaaaa better than 3 times that now
Old 04-28-2015, 05:42 PM
Celto 4's Avatar
ok upper manifold is off...........question is do i just do the o ring seals or replace the injectors on those two cylinders whats the experience here?????
Old 04-30-2015, 06:55 AM
Celto 4's Avatar
gooday i have ordered a leak down tester so hopefully can diagnose things here before going any further........i would think i could bubble check the injector o rings while the the cyl is under pressure ???
Old 04-30-2015, 06:52 PM
dgi 07's Avatar
You could, in theory. A little unorthodox, but it seems feasible.
Gromeo
01-24-2013 03:41 PM
ta981
06-10-2006 02:15 PM
Scott2747
02-08-2006 12:11 AM
cottonpatchweims
08-15-2005 11:19 PM
tbesselman
06-01-2005 01:54 PM
Quick Reply: misfire
