misfire
Old Apr 27, 2015 | 11:08 AM
Celto 4's Avatar
well iguess thats that did the compression test warm on #1&#7 120 still
Old Apr 28, 2015 | 06:48 AM
Celto 4's Avatar
good morning just a quick opinion here....is there any benifit to doing the cooling system pressure check at this point i will have to drive a half hour each way for a test kit i have no evidence of anti freeze in the oil and no overheating when running just the low pressure readings in the left bank thanks for any suggestions
Old Apr 28, 2015 | 09:44 AM
abran's Avatar
Are you still chasing the misfire? Do you feel the misfire, as in the engine running rough? Another member told me about a technique he calls baptizing.
Poor water around all the fuel injectors while the motor is running, if the roughness/misfire goes away you need to replace your injector o rings.
If you have the money, buy a pressure tester on eBay. Around $100.
Old Apr 28, 2015 | 01:16 PM
Celto 4's Avatar
hi yesthank you for your reply almost dont know it at idle only under load and acceleration no vapor in exhaust and oil clean what i came up with as a guess pulling upper manifold question the bracket thats in front of the secondary air passenger side do i have to remove that metal line from the manifold or can i wiggle out
Old Apr 28, 2015 | 01:33 PM
abran's Avatar
Not sure what metal line you are talking about. You should only have to remove the nut/studs from the SAI connections to the manifold.
If you are talking about the throttle cables, yes, unbolt bracket and put to the side.
Old Apr 28, 2015 | 03:54 PM
Celto 4's Avatar
got it double nutted the stud
Old Apr 28, 2015 | 03:58 PM
Celto 4's Avatar
bit out of practice did a lot of engine work in my 20's and imported them a long while back but its coming back im aaaaaa better than 3 times that now
Old Apr 28, 2015 | 05:42 PM
Celto 4's Avatar
ok upper manifold is off...........question is do i just do the o ring seals or replace the injectors on those two cylinders whats the experience here?????
Old Apr 30, 2015 | 06:55 AM
Celto 4's Avatar
gooday i have ordered a leak down tester so hopefully can diagnose things here before going any further........i would think i could bubble check the injector o rings while the the cyl is under pressure ???
Old Apr 30, 2015 | 06:52 PM
dgi 07's Avatar
You could, in theory. A little unorthodox, but it seems feasible.
Gromeo
Jan 24, 2013 03:41 PM
ta981
Jun 10, 2006 02:15 PM
Scott2747
Feb 8, 2006 12:11 AM
cottonpatchweims
Aug 15, 2005 11:19 PM
tbesselman
Jun 1, 2005 01:54 PM
