So, I've got an interesting question. [Gauges]
So, I have this problem. I keep trying to give my Disco little sports car like attributes while maintaining and even increasing its off road capability. It's like a disease, I want my cake and eat it too. Anywho, here's the hair brained idea I have now. You know how the instrument cluster on really high end sports cars, when you first turn on the car, all the gauges max out and then float back to where they are supposed to be? Yea, I want to do that. However, I have no idea what it's called, I have no idea how it works, and I have no idea how to search for it. So, any ideas?
My glow shift coolant and oil pressure do this already.
But to answer your question: there's no way to do what you want with a stock cluster unless you write custom software that energizes the potentiometers in the individual gauges.
OR
Create a custom hardware solution that goes in-line with the tach and speed signals and "plays back" a parabolic analogue signal range to sweep the gauges high to low when an ignition cycle is started.
OR
Just leave the damn cluster alone. :-p
OR
OR
.....................................You know how the instrument cluster on really high end sports cars, when you first turn on the car, all the gauges max out and then float back to where they are supposed to be? Yea, I want to do that. However, I have no idea what it's called, I have no idea how it works, and I have no idea how to search for it. So, any ideas?
Alex, you obviously have too much money and time on your hands, you must be good for a loan eh
Gauge scan system self test. Not all gauges/systems can do this by any means and it is often initiated by the engine ECU in conjunction with the general systems ECU or BCU. Most D2 systems do a self test hence the warning light/system test initially at the ignition position 2.
Haha, not enough of either I'm afraid. College has sucked me dry of both. Still, I can't help but conjure up some new project on the truck. It's absolutely addictive, like cocaine.
