Pressure Testing Coolant System - Work Around
Old 08-26-2011, 12:40 AM
marshman442's Avatar
Default Pressure Testing Coolant System - Work Around
I've read somewhere on here that there is a way to pressure test your coolant system throught the Intake Manifold coolant line.
I rented the pressure tester from Auto Zone and of course it does not have the adaptor for the our Res. Tank. So in the interest of time I am thinking of pulling the line that runs to the intake and plugging the mainfold side with plug and pressurizing the system through the small line running into the side of the res. tank.
Any thoughs?
Old 08-26-2011, 04:45 PM
disc oh no's Avatar
I would think that this would work okay, do you have a pressure regulator for the air pressure? You may need one to prevent blowing anything out! If it works let us know.
Old 08-26-2011, 06:29 PM
18 psi for 15 minutes seems to be the bench mark.
Old 08-26-2011, 09:11 PM
Rovin4life's Avatar
16psi, not 18 read the cap.
Old 08-27-2011, 09:07 AM
Go to a radiator shop and have them do it the correct way so you don't get an inaccurate reading and or break one of those lines.
Savannah Buzz
01-12-2015 03:33 AM
Phatrowles
08-26-2013 07:11 AM
bmt213a
11-26-2012 09:03 AM
landover
12-14-2010 10:42 PM
Quick Reply: Pressure Testing Coolant System - Work Around
