Pressure Testing Coolant System - Work Around
Old Aug 26, 2011 | 12:40 AM
marshman442's Avatar
Default Pressure Testing Coolant System - Work Around
I've read somewhere on here that there is a way to pressure test your coolant system throught the Intake Manifold coolant line.
I rented the pressure tester from Auto Zone and of course it does not have the adaptor for the our Res. Tank. So in the interest of time I am thinking of pulling the line that runs to the intake and plugging the mainfold side with plug and pressurizing the system through the small line running into the side of the res. tank.
Any thoughs?
Old Aug 26, 2011 | 04:45 PM
disc oh no's Avatar
I would think that this would work okay, do you have a pressure regulator for the air pressure? You may need one to prevent blowing anything out! If it works let us know.
Old Aug 26, 2011 | 06:29 PM
18 psi for 15 minutes seems to be the bench mark.
Old Aug 26, 2011 | 09:11 PM
Rovin4life's Avatar
16psi, not 18 read the cap.
Old Aug 27, 2011 | 09:07 AM
Go to a radiator shop and have them do it the correct way so you don't get an inaccurate reading and or break one of those lines.
Phatrowles
Feb 12, 2025 10:29 AM
Savannah Buzz
Jan 12, 2015 03:33 AM
bmt213a
Nov 26, 2012 09:03 AM
landover
Dec 14, 2010 10:42 PM
