Engine & Internal Chat about beefing up your engine's insides here.
engine swap
Old May 16, 2007 | 01:50 PM
double R's Avatar
Default engine swap
what other engine fits a 1995 range rover
Old Aug 28, 2007 | 08:26 PM
SuperCharged06's Avatar
Default RE: engine swap
Could you ram a new 4.2 supercharged v8 in there?
I think shoving one in my d90 would be nuts...lol.....but to be honest, i have no actual info to help you. Just thoughts [8D]
Old Aug 28, 2007 | 10:09 PM
llesra's Avatar
these drop in
3.9
4.0
4.2
4.6
Old Oct 30, 2007 | 11:24 PM
N.Franklin's Avatar
ORIGINAL: llesra
these drop in
3.9
4.0
4.2
4.6
That for discos as well? Do I need a ECU from the donor vehicle with the 4.6 if I go that route or can I slap in a superchip?
Old Oct 31, 2007 | 10:24 AM
okdiscoguy's Avatar
you can use your existing heads and ecu and bolt up a 4.6. I think you have to shave the front cover and a few other things, but you can use a 4.6 on a 4.0 system. Check out this link.......
http://home.twcny.rr.com/eeibooks/rover/engine.htm
Old Oct 31, 2007 | 10:42 AM
ajh's Avatar
ajh
Yeah, be thankful you're not trying to add a bigger engine to a new vehicle. Oh the pain.
Old Nov 9, 2007 | 12:50 AM
Bartell's Avatar
ORIGINAL: okdiscoguy
No. When one switches from a 3.5/3.9/ 4.2 to a 4.6/ 4.0, a spacer will be required at the crankshaft bolt and a special plug (or something you can fashion yourself) to close opening to the flywheel. The only other thing for fitting to watchout for is your sump, whch will need a couple of whacks with a ballpean hammer in front or ther crank will not clear, test with plastercine to find where. You must use a cam lube for start-up and a high level of zddp oils for the first 1000 miles.
However, in the end, you will be aggravating the problem that caused the failure shown on the link above unless you remap your fueling with a Tornado chip and/or buy one of the new comcast blocks.
James
bennyb43
Dec 11, 2013 08:17 AM
double R
May 16, 2007 06:05 PM
RJADM2000
Mar 3, 2007 02:06 PM
xb70valkarye
Sep 22, 2006 10:45 AM
Justin
Feb 11, 2005 01:55 AM
