Sponsored by: DashLynx
Safe way to remove exhaust flange bolts?
Old 10-02-2011, 05:55 PM
I got you now lordmorpeous.
Old 10-03-2011, 08:44 AM
Rovin4life's Avatar
if you have an impact then just heat the truck up and you can do the rest with a torch. Heck it takes five minutes to pull the intakes and fifteen to torch them out and install new ones. Trust me, torching is the easiest way.
Old 10-03-2011, 11:31 AM
While I have not done this yet, i will take photos and post. For guys re-doing head gaskets, are they time ahead to leave exhaust manifolds attached?
Old 10-03-2011, 11:57 AM
Paul Grant's Avatar
I only use an impact on these nuts. I never do them by hand.
Old 10-03-2011, 05:03 PM
s10lowrider1994's Avatar
For the head gaskets if its easier, its certainly ok to leave the manifolds attached. If you've already got the flanges loose it makes no sense to pull the manifold from the head. If you are going to get the heads worked make sure you take the manifolds off before you leave them at the machine shop. Some places like to charge extra for removing and reinstalling the manifolds.
Old 02-15-2016, 10:23 PM
mr4x4's Avatar
Smile exhaust flange bolt that connects pipe to the manifold snapped for me
exhaust flange bolt that connects pipe to the manifold snapped for me. I was doing a transmission filter change and the bolt that secures the pipe to the exhaust manifold broke off. I think it's because I'm so strong lol. anyway should have used PB blaster. Should i drill it out and replace it or is there a way to spin it out. The stud is what broke but it's flush with the hole.
Old 02-16-2016, 10:08 AM
drowssap's Avatar
"I" would drill it out, stud that have been heated and cooled that many time rarely spin out. jmho
Old 02-16-2016, 10:34 AM
mr4x4's Avatar
That's very true i'll try to spin out the stud with penetrating fluid and vice grips. If that doesnt work. I'll have to use the drill.
jalodge
04-15-2014 03:01 PM
CANAMDiscovery
12-13-2012 09:31 PM
Street Wolf
06-24-2011 01:59 AM
lipadj46
06-11-2009 01:30 PM
mcvickoffroad
03-06-2009 09:02 AM
Quick Reply: Safe way to remove exhaust flange bolts?
