Sponsored by: CARiD
Safe way to remove exhaust flange bolts?
Old Oct 2, 2011 | 05:55 PM
I got you now lordmorpeous.
Old Oct 3, 2011 | 08:44 AM
Rovin4life's Avatar
if you have an impact then just heat the truck up and you can do the rest with a torch. Heck it takes five minutes to pull the intakes and fifteen to torch them out and install new ones. Trust me, torching is the easiest way.
Old Oct 3, 2011 | 11:31 AM
While I have not done this yet, i will take photos and post. For guys re-doing head gaskets, are they time ahead to leave exhaust manifolds attached?
Old Oct 3, 2011 | 11:57 AM
Paul Grant's Avatar
I only use an impact on these nuts. I never do them by hand.
Old Oct 3, 2011 | 05:03 PM
s10lowrider1994's Avatar
For the head gaskets if its easier, its certainly ok to leave the manifolds attached. If you've already got the flanges loose it makes no sense to pull the manifold from the head. If you are going to get the heads worked make sure you take the manifolds off before you leave them at the machine shop. Some places like to charge extra for removing and reinstalling the manifolds.
Old Feb 15, 2016 | 10:23 PM
mr4x4's Avatar
Smile exhaust flange bolt that connects pipe to the manifold snapped for me
exhaust flange bolt that connects pipe to the manifold snapped for me. I was doing a transmission filter change and the bolt that secures the pipe to the exhaust manifold broke off. I think it's because I'm so strong lol. anyway should have used PB blaster. Should i drill it out and replace it or is there a way to spin it out. The stud is what broke but it's flush with the hole.
Old Feb 16, 2016 | 10:08 AM
drowssap's Avatar
"I" would drill it out, stud that have been heated and cooled that many time rarely spin out. jmho
Old Feb 16, 2016 | 10:34 AM
mr4x4's Avatar
That's very true i'll try to spin out the stud with penetrating fluid and vice grips. If that doesnt work. I'll have to use the drill.
jalodge
Apr 15, 2014 03:01 PM
CANAMDiscovery
Dec 13, 2012 09:31 PM
Street Wolf
Jun 24, 2011 01:59 AM
lipadj46
Jun 11, 2009 01:30 PM
mcvickoffroad
Mar 6, 2009 09:02 AM
