Manual lock and key remote
Old 12-30-2011, 11:20 AM
bribake's Avatar
Default Manual lock and key remote
Hi all, my key remote has not been working for some time now so I have been using the manual lock to lock/unlock my LR3.
Now the manual lock has stopped working, meaning the key won't lock/unlock the door. Has anyone else had to replace the lock?
Happy Holidays!
Old 12-30-2011, 12:55 PM
mirepoixmatt's Avatar
Really. That's a shccker! It doesn't turn?
Old 12-30-2011, 01:38 PM
bribake's Avatar
Turns a little but lock wont engage.
Old 12-30-2011, 08:20 PM
Rovin4life's Avatar
you may have something beside the lock broken, you have to pull the door panel off.
but if the remote doesn't work its possible the green and white wire on the passenger side is corroded and needs a simple repair.
Old 12-30-2011, 11:38 PM
bribake's Avatar
Thanks. How hard is it to get the door panel off? I imagine that would need to be removed on the passenger side to access the green and white wire.
Old 05-29-2012, 07:53 PM
mbamka's Avatar
Hi, same thing happened to us today. How did you resolve? Which costs more, the new key or fixing the broken lock?
We also had the same issue with corroded wires that impacted the remote operation. Fixed the wires under passenger side, and then had to fix the corroded wires under driver side about a year later.
Old 05-29-2012, 10:34 PM
Here's info on the panels, etc.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 05-31-2012, 01:06 AM
bbyer's Avatar
Default may be nothing actually needs replacement
Sometimes the locking cams, rods and levers inside the door get out of sync with each other. If the power door lock and unlock buttons on the middle dash still operate, try electrically locking and unlocking the doors a few times. Sometimes that will get the bits back in place.
If you have to tear the door card off, then try the same thing, but with your fingers. Probably nothing has broken, just bits got out of place.
Old 06-20-2012, 02:39 PM
bmartindale's Avatar
Happy Holidays!
I just had a similar issue, my remotes decided to stop responding one day, they now work periodically. Used the manual locks for awhile, then one day, manual lock doesn't work. turn it opposite direction, unlocks but when I open the door the alarm system goes off until I get in and turn the key in the ignition. I've noticed yesterday, I hit the lock/unlock buttons to see what happened, it did nothing, but later when I was walking outside to my other car and get something out of the trunk, the LR3 lights started flashing 6-9 times very fast and then locked itself(it was unlocked before)
I know its not the key, because I have two fobs and both stopped working at the same time. I have had issues before where the car wouldn't start unless I put it into neutral, but believe that was due to the old linkage.
Any ideas anyone?
EDIT: Will check wires today out of curiosity, but I don't think the wires are bad because the remotes work periodically. Now every time I used the manual unlock the alarm goes off but is silenced by the key being put in ignition.
Rover_Hokie
05-21-2012 03:53 PM
RROJ
10-09-2010 07:39 AM
RROJ
10-08-2010 09:56 PM
Jay
04-27-2005 03:49 PM
Quick Reply: Manual lock and key remote
