Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 06-24-2011, 08:22 AM
Junior Member
Default P38 battery drain
Have 1996 P38. Recently if the car is sitting for 3 or more days the battery drains. I can't find anything on. However, the seat belt mechanism has failed at the same time -- belt won't retract and I get a constant SRS and AIRBAG FAULT warning light.
Can the seat belt mechanism failure induce anything to stay on and drain the battery over time?
Any suggestions? I've run an OBD-II scan, nothing comes up.
HELP!
Old 06-28-2011, 07:28 PM
Senior Member
battery drain starts with an Ammeter reading. if should be less then 50 milliamps with everything off. if not you got a drain. Then start pulling fuses till you find the culprit circuit and start by checking for damage to those circuits.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Tags
1996, 25, battery, belt, correct, drain, drains, draw, p38, problem, range, rf, rover, seat, sitting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
