P38 battery drain
Old Jun 24, 2011 | 08:22 AM
faversham's Avatar
Default P38 battery drain
Have 1996 P38. Recently if the car is sitting for 3 or more days the battery drains. I can't find anything on. However, the seat belt mechanism has failed at the same time -- belt won't retract and I get a constant SRS and AIRBAG FAULT warning light.
Can the seat belt mechanism failure induce anything to stay on and drain the battery over time?
Any suggestions? I've run an OBD-II scan, nothing comes up.
HELP!
Old Jun 28, 2011 | 07:28 PM
Rovin4life's Avatar
battery drain starts with an Ammeter reading. if should be less then 50 milliamps with everything off. if not you got a drain. Then start pulling fuses till you find the culprit circuit and start by checking for damage to those circuits.
stusanderson
Aug 5, 2012 04:33 PM
Rustybug
Jan 31, 2009 02:53 PM
shawnjones
Apr 24, 2008 03:15 PM
kingkitesurf
Jul 28, 2007 11:54 PM
Dopey
Jul 22, 2007 07:09 PM
