19 inch or 20 inch
Old Sep 10, 2023 | 08:56 PM
  #21
GavinC's Avatar
Originally Posted by jsis333
I'm new to this forum and am in the process of "building" a new defender 110; I'm surprised that these huge SUVs start out with such small tires (19 inch). First of all, I'm not an off road guy, I'm a soccer dad with loves the classy but rugged look of the Defender; I don't need all that off-road stuff but I do want to look good and have nice handling as I driver the kids through the burbs. Should I get the big 22 inch wheels or are the 19 inch sufficient?
The tires are all 32"
LR have the following rims on offer:
18" as small as we can get and still too big. Lots of choices in tires.
19" No tire choices.
20" No sidewall and lots of choices.
22" Make me want to cry just a little bit. Enormously popular, enormously ridiculous.
Aftermarket options
24" Consult a neurologist.
Old Sep 14, 2023 | 09:33 PM
  #22
is21447's Avatar
Apologies if this has been asked but what is a sidewall and why is it useful when off-roading?
Old Sep 15, 2023 | 10:40 AM
  #23
mrego's Avatar
All due respect, but if you don't know what a sidewall is and why useful when off-roading you probably want to go with 22s or 24s.
Old Sep 16, 2023 | 07:31 AM
  #24
PaulLR's Avatar
Taller sidewall = less chance of rocks damaging your wheels. Also allows you to air down more. Stronger, reinforced sidewall materials prevent rocks from cutting into the tires. (Unlike the OEM Goodyear Wrangler sidewalls)
Old Sep 18, 2023 | 03:12 PM
  #25
SpyHop's Avatar
The 19's are perfect for comfort and also allow for some mild off-roading. Larger wheel sizes (20"etc) have less rubber between the wheel and the road so may ride more harshly. Basically, as stock the tires will all have a 32" diameter, it's just how much sidewall/rubber you want. Think lower profile tires with the 20" rims and lots more sidewall for the 19" rims. Same dimension for each though. That said, I have the 19" wheels and good luck finding snow tires if you want em.
Old Sep 18, 2023 | 05:58 PM
  #26
is21447's Avatar
Thanks for the nice responses, you guys are the best!
Old Sep 22, 2023 | 08:19 AM
  #27
Hugha's Avatar
Originally Posted by TrioLRowner
Yep ... No idea why JLR offers the 19" on its premier off-road vehicle without making sure to tell folks they are not recommended due to tire market off-road lack of availability. They did the same on the LR4 ( very frustrating).
I went with 19s because that was the smallest rim they offered for the P400. I wish they had warned me there are maybe 2 choices for 19" A/Ts.
Old Apr 8, 2024 | 09:39 PM
  #28
Tatemalone's Avatar
Question
Originally Posted by Kev M
We purposely ordered the 19" over the 20" for more sidewall and even if the choices are limited they are sufficient for our uses (mostly on-road, but off-road is primarily beach/dunes - sugar sand in the OBX and NJ pinelands).No regrets for our use even with the road biased Scorpions.
​​​​​​I know that this has probably been inactive for a while but I am considering going with the 19" wheels on a '24 defender to improve ride quality. Does it really make a difference in ride opposed to the 20"? I don't plan to offroad much (just in a dry field or in deer hunting land). Do the all terrain tires that come on the 19" make a lot more noise than the all seasons? Thanks.
Old Apr 9, 2024 | 07:01 AM
  #29
Hugha's Avatar
I just put all terrains on my 19" wheels. When I mentioned to a buddy that I did not really hear any additional road noise, his comment was "you have a luxury vehicle". In other words, Land Rover did a good job with sound insulation.
I went 19s with the intention of offroading. I was not aware that only one manufacturer makes 19" all terrain tires. If sidewall depth is not a concern, stick with 20s as you will have significantly more tire choices.
Old Apr 9, 2024 | 11:20 AM
  #30
Jim 90's Avatar
I have a 2023 D90 and a D110 both with Duratrac 19”. While I agree with most of the comments above I would repeat some - good ride, very acceptable noise, good traction (including snow although no tread tires would have been sufficient in Wisconsin this year), very pleased. Both Duratrac and KO2(3), are out with new tires. Not sure if either fit any Defender wheels yet. Some on the forum seemingly change tires every time a weather front moves in (no complaints), just not for me. I would probably put more wear and tear on the tires getting to, and back MOAB/RUBICON, than on the trail. Or I could do the TFL thing a drive a new defender straight from the showroom on on-road tires, go rock climbing and blame Land Rover. In short, when I need new tires, I will consider the 20’s but not feel compelled.
