Havoline Antifreeze Substitute
Old Nov 22, 2022 | 09:20 AM
GrouseK9's Avatar
Anyone checked ebay yet?
Old Apr 7, 2025 | 09:26 AM
redrover75's Avatar
Old thread, but I found this info.
  • Havoline Extended Life Coolant is an OAT coolant: It uses organic acid technology for corrosion protection, which is different from the traditional silicate-based antifreeze.
  • OAT coolants are generally compatible: You can use other OAT coolants as a substitute.
  • Avoid mixing different types: Do not mix OAT coolants with silicate-based antifreeze, as this can cause problems.
  • Check for compatibility: Always check the manufacturer's recommendations for your specific vehicle model, as some vehicles may have specific coolant requirements.
  • Examples of OAT coolants:
    • Texaco XLC
    • Delo XLC
    • Valvoline Zerex G-05
    • Prestone All Makes All Models Extended Life
    • Shell Dex Cool
    • Valvoline Zerex Extended Life Coolant
jafir
Jul 14, 2013 11:38 AM
jhill15
Feb 12, 2013 07:12 PM
stephane
Dec 9, 2012 06:47 PM
thepaleowolf
May 22, 2012 07:25 PM
Evian
May 17, 2006 08:31 AM
