Headlight failure (led ring/DRL)
Old Feb 12, 2026 | 08:38 AM
  #181
nitesoul's Avatar
my 2020 first edition driver side just went out after the passenger went out a month ago , thank god for CPO warranty
Old Apr 10, 2026 | 09:55 AM
  #182
Mantis's Avatar
L663 MY 2023.5 110X USA Left Hand Drive // My Right Passenger side DRL went out at 52K miles and now the Left Driver side DRL is out at 67K miles. I will repair this myself but need to get a right LED module that will have the same brightness as OEM. I read a review of the non-OEM module not being bright enough and does not match the OEM lumens; appears to be part # UBL 3036--A/00 1184, also sold as DA5319. QUESTION: what LED module that will match the lumens of the OEM and where can I purchase it? Also, is there a repair shop in Colorado, USA that will repair these? Thanks, Mantis
Old Apr 10, 2026 | 10:06 AM
  #183
2020Defender's Avatar
I bought the LED module from powerful uk ltd. I did the left one first I think from memory. Brightness matches the remaining side. Then the other side failed a short time later. It takes about 2-3 hours to do. Just plan for that labor cost if you aren't doing it yourself. Plus the ~$75 for the part.
Old Apr 10, 2026 | 10:57 AM
  #184
GavinC's Avatar
You can get a wide range of pricing on the DRL module.
I got mine from Aliexpress
$2.38 including shipping.
I have no idea how but that’s what I paid. There are oodles of options to buy.
Some seller were selling them in packs of 2, 4 or 10
Old Apr 10, 2026 | 11:26 AM
  #185
DoctorofRocks's Avatar
Could you share a link? For that price I would order some to have as spares.
Old Apr 10, 2026 | 05:01 PM
  #186
GavinC's Avatar
Its been a while since i bought it but a quick google search found these in seconds.
$6 for 4 seems good value.
Old Apr 13, 2026 | 09:02 AM
  #187
Mantis's Avatar
Where did you get your DRLs fixed?
Old Apr 13, 2026 | 06:05 PM
  #188
GavinC's Avatar
DIY at home.
Old Apr 24, 2026 | 02:00 PM
  #189
cbell2112's Avatar
Just had my p400 in for repair. I was just going to have the shop disable the DRL's using a GAAP tool but he pointed out that the front turn signal only flahses once when actived then the 2 little squares illuminate for less than 5 seconds and then everything goes dark. Are the DRL's and turn signal controlled by that same module? I didn't think so but he said they were.
Old Apr 24, 2026 | 02:03 PM
  #190
GavinC's Avatar
No
This is complete nonsense from the shop
