Towing an Airstream Basecamp 20x with 110 p400 questions
Old Jan 4, 2024 | 04:34 PM
  #21
POPTOPP's Avatar
Originally Posted by wlindsey@gmail.com
how do you manage the hitch weight? We’re interested in getting a 25’ AS but the hitch weight is 150lbs over spec. Looking for ways to solve the problem. Love the 25’ configurations.
I drove up to CanAm RV in Ontario Canada to have the hitch strengthened. This does not interfere with the departure angle. Also, check those specs again. Our 25 GT FBT is spec'd as 885lbs. Furthermore, that tongue weight is very dependent on loading. While many AS folks will say they are over spec at 1,000lbs, we are under - actual tongue weight is 800lbs as measured at the CAT scales.
Old Apr 20, 2024 | 11:02 AM
  #22
Willd2021's Avatar
5th Gear
Originally Posted by MackT83
Did you ever figure this out? I have a 20x Basecamp on the way and need to figure out the towing solution for this spare tire and brake controller issue.
I haven't really. I did what others have mentioned by moving my spare to the roof rack. However, I'm still exploring a way to extend the trailer tongue or perhaps a different hitch jack configuration as I need better access to the spare and don't want to lose the roof rack capacity as sometime I carry a rooftop tent and really use the basecamp as, well, a base camp.
Old Apr 20, 2024 | 11:09 AM
  #23
TeddyG's Avatar
Make a spare tire storage bracket on the trailer, I'm thinking it's cool.
Basecamp is light, you can extend hitch like i did but it messes up all tow assist stuff and puts a little more tension on factory hitch bracket.
Old Apr 20, 2024 | 11:20 AM
  #24
Willd2021's Avatar
5th Gear
Thanks. That is an option but when I disconnect for the basecamp and want to go, I have to transfer the spare. I have never found the trailer backup assist user friendly so I may just use a modest extension like you did or beef it up as also mentioned. This seems to be one of those "it shouldn't be this hard things" but haven't found a great solution so far.
Old Apr 23, 2024 | 07:17 PM
  #25
pinion's Avatar
Since this thread has a lot of good towing discussion it seems like a good place to show how I solved the brake controller setup… pretty satisfied with how it turned out.
Old Apr 24, 2024 | 10:25 AM
  #26
Jim 90's Avatar
What are the best/recommended brake controllers (to include installation) for the defender 2023?
Old Apr 28, 2024 | 08:46 PM
  #27
Huc's Avatar
Huc
For what it's worth, I have a RedArc tow pro elite and it works great. If I recall I thought there was a detailed thread on that product.
Vintage12
Oct 6, 2023 08:43 AM
Hudson5150
May 4, 2023 07:58 PM
Defensor
May 23, 2022 03:20 PM
MNDefender
Sep 8, 2021 09:40 AM
Ehloo
May 14, 2021 10:09 AM
