Trickle charger for Defender 2021 P400 HSE
Old Nov 9, 2024 | 10:53 AM
swajames's Avatar
Every time I've had a software update fail to install it's been down to low charge on the 12v. A trickle charge solved the problem every single time. These vehicles absolutely benefit from regular driving and if you aren't using it enough occasional trickle charging. I have the CTEK that the OEM Land Rover charger is based on.
Old Nov 9, 2024 | 12:09 PM
Jim 90's Avatar
CTEK seems to be popular for European cars. I have used both Battery Tender and NOCO with good success. Make sure it is set for AGM. Higher the Amp quicker the charge, but time should not be an issue.
rakusak
Jun 17, 2024 07:49 AM
mopadzi
Jul 31, 2023 02:08 AM
Shahi92
Apr 29, 2022 04:50 AM
Armin_1
Nov 24, 2021 06:48 PM
ebarry
Dec 20, 2020 12:25 PM
