Wind dam for expedition roof rack
Old Oct 29, 2022 | 02:48 PM
  #41
brundog's Avatar
Yes I would say it takes care of about 80 percent of the wind noise with the roof open.
Old Oct 29, 2022 | 02:50 PM
  #42
brundog's Avatar
It is the 9" x 52" with what they call a reverse smile.
Old Dec 18, 2022 | 06:11 PM
  #43
denhams's Avatar
I'm expecting my Colorado Fairing this week. To remove the front cross piece, do you just need to undo the two hex bolts on the back?
Old Dec 18, 2022 | 07:56 PM
  #44
Jrunr619's Avatar
I’m my head, I always wonder why no one makes a clear/tinted wind fairing so we could put a light bar behind it and have it shine through.
In theory, it would give the best of both worlds: a roof mounted lightbar with zero added wind noise…
Old Dec 19, 2022 | 08:24 AM
  #45
DonMitsu's Avatar
It's not easily removable. I ended up using a dremel to cut 2 slots in it for the fairing bracket. There are 4 brackets, the 2 on the outside are outside of the cross piece, the center ones can be mounted without cutting, but it's awkward.
Old Dec 19, 2022 | 09:04 AM
  #46
brundog's Avatar
Sorry for the delayed response.
You are not taking the center section off, it is removed quite easily where the curved section meets the straight side pieces. loosen the first cross piece and push it back, this will expose a hex screw on each side remove them and the whole thing slides out. This way you can drill all the holes on the work bench.
Old Dec 19, 2022 | 12:05 PM
  #47
denhams's Avatar
Thanks. That works. I've attached a couple of photos. You need a Torx T30 security bit and an 8mm socket.
Here is how I mounted the fairing after removing the rack’s front center section.
Start with the outer brackets, attach them to the fairing and then clamp them to the center section. Offer it up to the rack to align everything. Remove it again and mark holes to drill for the outer brackets.
Remove the outer brackets from the fairing and bolt them to the center section with M8 hex bolts and Nylock nuts. Bend down the leading edge of the outer brackets slightly to ensure a good fit of the ends of the fairing to the roof.
Now the center brackets. I decided not to cut anything so bent up the trailing end of the center brackets by 90 degrees to fit against the center section’s air dam. Note, this cracks the paint on the bracket so I had to respray them and also did the mounting bolts that came with fairing at the same time.
Mount everything to the fairing and drill holes in the center section air dam and bolt on the center brackets (M8 hex bolts, Nylock nuts). You need to bend the trailing end of the center bracket or it will touch the roof.
Replace the center section in the rack with the fairing attached and bolt it in place. Replace the rack’s front cross rail.
Old Dec 21, 2022 | 11:16 AM
  #48
FWCycles12$'s Avatar
who is we build custom racks?
Old Jan 20, 2023 | 08:56 AM
  #49
Jim 3997's Avatar
4th Gear
Default removing first crossbar
Thanks this very helpful. I however, cannot slide the first crossbar back to get to the hex nut to remove the front piece. The hex nut itself blocks the travel of the bar through the slots. Any suggestions?
Old Jan 20, 2023 | 02:34 PM
  #50
denhams's Avatar
Hmm, I guess if you can't get to it, then you could take the rack off. It's pretty quick - 6 bolts each side (6mm hex drive). Remove the small plastic covers to get to the rear ones. You'll need someone else to help lift it off. That will enable you to measure and drill off the car. After that, you can fit the fairing with the rack back on the car.
BTW, I've driven many miles on- and off-road. Nothing has come lose or moved. The fairing noticeably reduces wind noise.
