4.6 engine build
Old Mar 30, 2015 | 09:19 PM
  #111
TOM R's Avatar
I could not source the size local so I welded bungs shut then stacked nuts on pipe , welded them together and screwed the sensors in, same thing
Old Apr 2, 2015 | 09:17 PM
  #112
dusty1's Avatar
Default seal'r up
irontite ceramic seal @ 180 degrees with 3 gallons of h2o. 12-18hrs
this is supposed to be an armor against over heat and provide extra heat dissipation. basically, i am heat treating a ceramic coat in all the water ports to smooth surfaces and keep it from cracking
Attached Thumbnails 4.6 engine build-dsc_7252.jpg   4.6 engine build-dsc_7253.jpg   4.6 engine build-dsc_7254.jpg
Old Apr 2, 2015 | 09:46 PM
  #113
TOM R's Avatar
Wtf
Old Apr 2, 2015 | 10:10 PM
  #114
dusty1's Avatar
It's the block seal not the head gasket in a bottle
Old Apr 3, 2015 | 08:11 AM
  #115
drowssap's Avatar
Almost like that minning slully that someone else uses,
Old Apr 3, 2015 | 08:44 AM
  #116
dusty1's Avatar
Your idea, Drow. So if I pull these hoses off and find a solidified turd, in what used to be a water port...........
I should have used a smaller water pump. This one was too much @1500 gph
Old Apr 3, 2015 | 10:33 AM
  #117
drowssap's Avatar
i think your right, i think a slow even flow would be better
Old Apr 3, 2015 | 02:35 PM
  #118
TOM R's Avatar
Well picked up. My 4.6 crank,rods,pistons from rovermastertech in wall n.j.
Looked at a bare block he had, there is no way to pull all pistons from the bottom due to the casting of a few main bearing housings so looks like I am pulling heads again ugh
Old Apr 3, 2015 | 03:48 PM
  #119
drowssap's Avatar
Did you use studs?
Old Apr 3, 2015 | 10:08 PM
  #120
TOM R's Avatar
Originally Posted by drowssap
did you use studs?
nope i did not
