my 98 disco1
  #241
Old 04-27-2014, 07:33 PM
TOM R's Avatar
PAINT THREAD https://landroverforums.com/forum/di...y-paint-66697/
Decal thread. https://landroverforums.com/forum/di...-decals-66841/
  #242
Old 05-06-2014, 08:53 PM
TOM R's Avatar
Rear main seal thread
https://landroverforums.com/forum/di...al-leak-66893/
Trans leaks
https://landroverforums.com/forum/di...97/#post462842
  #243
Old 05-13-2014, 08:33 AM
TOM R's Avatar
In an attempt to keep moving forward on all aspects between working and rain here is the roof rack cleaned primed and sprayed with rustolium bed liner, the rear clam was free from the trash and just picked up the pelican case for a good price at the Aberdeen military show last weekend, these should yield plenty of space for camping gear
  #244
Old 05-23-2014, 06:56 PM
TOM R's Avatar
  #245
Old 06-05-2014, 08:37 PM
TOM R's Avatar
Just installed 3rd disc changer I need ideas where to move it off the floor
We go wheeling it gets wet poof let the smoke out
  #246
Old 06-08-2014, 05:41 PM
TOM R's Avatar
Replaced this bad swivel big dark spot is heavy pitted
Actually got lucky pulled this whole assembly off another 98 in u pull last week so I installed in mine as an assembly makes it super fast that way, and this has a replacement caliper, mine old one was dragging
Think total for that assembly at u pull $50? Axle,knuckle, swivel, rotor, caliper, line, good pads, abs sensor
Without u pull I could not afford this vehicle
  #247
Old 06-08-2014, 08:27 PM
ihscouts's Avatar
Yes you would, you'd work on others and make cash and parts.......
  #248
Old 06-25-2014, 05:38 PM
TOM R's Avatar
Originally Posted by CUpgt
A ton of guys run skid plates so it may be a non issue. This is my current setup.
My old tube bumper had a skid but it barely came below the frame rails. You will have a good bit more protection on yours.
hope to get back on this soon, are the sides of that made from 3/16" ?
  #249
Old 06-26-2014, 01:11 AM
CUpgt's Avatar
I'll double check but I'm pretty sure the whole bumper is 3/16 and the winch plate and frame mounts are 1/4"
  #250
Old 06-26-2014, 06:08 AM
TOM R's Avatar
thanks thats what I figured trying to save a little weight where i can everything we did so far is 1/4"
Quick Reply: my 98 disco1
