my 98 disco1
Old Jun 24, 2015 | 08:44 AM
  #401
TOM R's Avatar
Finally got the power wire ran, these lights are blinding bright, 10 amp fuse seems fine to run 1 each on the small side lights, not enough to run that main bar, swapped in a 15 amp will see how that does
Old Jul 5, 2015 | 06:41 PM
  #402
TOM R's Avatar
Finally got these done today, took the front lip off the cubby, cut the back off the cubby, found a piece of plastic drilled and mounted, couple pop rivets and home made L brackets and voala, I ran the wires in the dash and plugged them into the fig lighter plug so that socket is now dead till I decide to pull the console
Old Jul 6, 2015 | 07:57 AM
  #403
Shiftonthefly1's Avatar
That's a great idea. Looks good.
Old Jul 6, 2015 | 09:43 AM
  #404
TOM R's Avatar
They are for a boat, came with a mount plate I could not use for that location
Think I got em on eBay Last year , I am catching up on a lot of things
Old Jul 6, 2015 | 01:08 PM
  #405
TOM R's Avatar
Did rear pinion seal at lunch today and did this extension for the pinion skid plate, now it goes under the axle housing for more protection, I am thinking I want to weld it to the bolt on diff protector
Because of what we do I believe the scrap steel I used is 1/4 ballistic steel, had to bend it in the shop press and cut with plasma cutter
Old Jul 9, 2015 | 05:29 PM
  #406
TOM R's Avatar
Work in progress home made front pinion guard, I still need to extend this under the housing
Old Jul 10, 2015 | 09:02 AM
  #407
TOM R's Avatar
see how much angle is on my front diff? should i attempt to correct that? seems my castor is probly off quite a bit
maybe the offset bushings for the control arms?
i did the proline cranked rear arms last year and the back diff sits level when truck is on the ground
Old Jul 10, 2015 | 10:36 PM
  #408
Tom my angle on my RR was nowhere near that. I had castor correct arms. Maybe you are lifted too high?
Old Jul 10, 2015 | 10:43 PM
  #409
TOM R's Avatar
2" OME HD and I got plenty of weight on it
Old Jul 19, 2015 | 09:49 PM
  #410
Buddy Lee's Avatar
The angle does not look that bad to me. The front is supposed to point up a little. With only 2" lift your caster would be off a little but I don't think enough to warrant the expense of trying to connect it. At 3" is where I really started to notice stuff.
