Defender Talk about the Land Rover Defender within.
Engine help
Old Dec 1, 2014 | 10:29 AM
Robert Cunningham's Avatar
Default Engine help
Hi.
I am babysitting my brothers Defender 110. I started it the other day and there was hardly any power. I took it down the road and it backfired a couple times but didnt recover.
I returned home to realise that fuel was pouring out. I decided to get a mechanic to come out, but this afternoon went to have a look myself and I found that when I start the engine the fuel is pouring from a black fuel line which is hanging loose. There are 2. I cannot figure out where they are supposed to be and how they came loose. Hoping someone can assist before Wednesday
Attached Thumbnails Engine help-img_2622.jpg   Engine help-img_2623.jpg   Engine help-img_2624.jpg
Old Dec 2, 2014 | 11:00 PM
Default Update
I have since learnt that the pipes are overflows from the pipes, so now I need to figure out what the problem is that is causing fuel to overflow from the carb.
Please help
Old Dec 5, 2014 | 09:45 AM
drowssap's Avatar
most likely a stuck float try wrapping on the side of the carb. a couple times, I'm assume those are twin solexs, they look a lot like the old SU's.
if one hose is draining then it is probably the float stuck open, if both over flows are leaking, check for to much fuel presure
Speed racer
Oct 11, 2008 10:56 PM
tcbinaflash
Jan 8, 2008 04:23 PM
cassie11
Jun 23, 2006 10:26 AM
