1998 D1 spark plug and wire install
Old Apr 5, 2013 | 04:56 AM
texasdisco1's Avatar
Good Morning I stayed up late last night double checking all wires to ensure they were routed per the diagram. And once again when all wires were routed per the diagram my D1 will not start, it will turn over but that's it. I've downloaded the rave manual, I've got it opened up on my tablet right under the hood for referencing. Anyone have any suggestions or solutions?
Old Apr 5, 2013 | 08:25 AM
1. Do you have spark?
2. If not, check fuse (F3, satellite fuse panel 1 under dash) associated with coils, and consider that crank position sensor may be unplugged or defective.
3. If spark is good, check fuel pressure at schraeder test valve on the right side of engine injecto fuel rail, needs 32-34 PSI. Will run for just a few seconds when key turned to position 2.
Old Apr 5, 2013 | 11:32 PM
Walko327's Avatar
use the rave for great instruction for pics and such. the coil pack is numbered if you look closely too that can help as well. great little write up on spark plugs.
Old Apr 5, 2013 | 11:34 PM
Walko327's Avatar
texasdisco1 check the main connector for the entire coil pack. after i did my heads i left this un connected causeing a no spark situation that was easily remedied. fired right up after snugged in all the way, it can be stiff so push hard.
Old Apr 6, 2013 | 06:11 AM
good catch on connector, here's a pix of C1002 from the RAVE.
File Type: pdf
Old Apr 6, 2013 | 07:18 AM
keoni004's Avatar
Default Rtfm
I had no idea there were component locations in the RAVE! That's what I get for not looking through the whole thing!
Old Apr 6, 2013 | 07:40 AM
Thanks for everyone's help, I figured it out yesterday morning. I pulled every wire out and started over. It fired right up and I was off to work.
Old Apr 6, 2013 | 07:42 AM
I do have another question, if I have a 2 " lift do I need +2 shocks? My rover has OME HD springs front and back.
Old Apr 6, 2013 | 08:36 AM
re: It fired right up
Yeehah! Ride em' cowboy!
CPDieker
Jun 6, 2012 09:36 PM
primey
Oct 26, 2011 07:24 PM
sdsilvere38
Jun 14, 2010 08:35 PM
werldcup
May 12, 2008 12:01 PM
kcirtap
Oct 10, 2007 06:43 PM
