2 Q's Red or green coolant, which side is bank 1
Old Nov 30, 2011 | 09:03 PM
many do, it is fine with green coolant, but the effect is usually only noticed in very warm temps. And - if your cooling system is up to snuff, won't need it.
Old Nov 30, 2011 | 09:06 PM
Discolife's Avatar
Surfactants work and do reduce corrosion on alum engine parts
Originally Posted by Spike555
Nope. I do not believe in snake oil's, if you need to add a additive to your motor oil, power steering, transmission, coolant etc. then you either have a problem that needs to be fixed or you need to use a different fluid.
Engines are designed to run at a certain temp, what is the point in trying to lower the temp as much as possible?
How much does this crap lower the temp buy?
If you want a colder running engine then just put in a colder t-stat.
It did not come from the factory with extra crap in the radiator, or the engine oil or the transmission, so why add it now?
I just dont get it.
Each to their own.
Old Nov 30, 2011 | 09:18 PM
It's all good mate, it's all good.
You wanna use it go for it.
robson
Feb 22, 2018 05:42 PM
wediveaxa
Sep 23, 2010 07:12 AM
salve7
Mar 9, 2010 06:06 PM
98roverguy
Sep 28, 2006 09:23 PM
