96 D1 - Drivers door can lock but no unlock?
Old Nov 16, 2010 | 09:15 AM
Paul_VR6's Avatar
Default 96 D1 - Drivers door can lock but no unlock?
Bought my Disco like this but just getting around to looking into it. Nothing in the search that I can find (within reason!). Broke my key in the door yesterday so I had the door panel off, which inspired me to look into it.
So all I see back there is a little microswitch with two wires, one black and one yellow. The yellow one looks to have been crimp repaired and then re-cut. Splicing it again has no effect.
I can unlock the pass side with the key, and lock/unlock with the pull pin on the inside.
Not sure what is used to unlock the door! All I can see on the inside is the key turning a cam that runs pas that microswitch..
Advice?
Old Nov 16, 2010 | 07:01 PM
If you are talking about no power unlock it is a weak power door lock actuator.
Mine was doing the exact same thing, I lubed the actuator with silicon spray and it has worked for 2 years now.
Old Nov 16, 2010 | 08:42 PM
Paul_VR6's Avatar
Thanks for the advice. I fiddled with it more at lunch, with no real rhyme or reason, and it's started to work. I'll post up again if it dies again and I have a legit fix.
Old Nov 16, 2010 | 09:29 PM
Danny Lee 97 Disco's Avatar
Spray some lube on all of your door lock mechanisms.
dan_t
Jun 26, 2022 08:11 PM
kpl1228
Aug 19, 2012 05:33 PM
jimmyfingers
Jan 27, 2011 03:22 PM
richierichrover
May 27, 2009 09:42 PM
CL_Reatta
Jul 3, 2007 12:00 AM
