Am I going crazy or is there some trick to this brake pin?? Urgent.
#32
X2 on that one. Check all of your hoses. If you have the factory clamps on the return lines, cut them off and use worm style hose clamps. Also make sure your pitman arm is not loose. If everything is good and still leaking from the box, add 1/3 bottle of white shepherd to it.
bcolins
12-10-2008 04:56 PM
