Anything I need to know about doing a front wheel bearing?
Old Sep 26, 2010 | 05:23 PM
Garrett's Avatar
Default Anything I need to know about doing a front wheel bearing?
I bought this kit:
SKF Wheel bearing kit.
Anything else I will need or any helpful hints? The repair manuals I have say it needs to be shimmed and such but a Land Rover tech told me not to worry about it and it's pretty straight forward to just replace the bearing??
Thanks guys!
Old Sep 26, 2010 | 09:17 PM
kenk's Avatar
The only thing I could think of, which is a maybe, is the lockwasher. It is re-usable a few times, so as long as its still decent and not all buggered up, you shouldn't need a new one.
I don't know of any shims in the hub/wheel bearing area. The only ones I can think of close are on the axleshaft, between the c-clip and drive member. But that shouldn't change any nessesitating new shims.
To remove the hub, the brake caliper has to come off. Some people remove the brake line to remove the caliper. But to save time bleeding brakes,etc, I remove the upper swivel pin bolts(17mm) and remove the brake line and bracket with the caliper and hang it with wire on the coil spring.
Old Sep 27, 2010 | 07:48 AM
antichrist's Avatar
No shims in the D1 hub, though there is one in the front under the axle circlip but I never change them.
If you off-road I wouldn't use that seal on the right, they suck for keeping crap out of the hubs. RTC3511 is the way to go.
Old Sep 27, 2010 | 06:50 PM
Danny Lee 97 Disco's Avatar
Do you have the big socket for removing the nut holding it all in place?
Old Sep 28, 2010 | 10:02 AM
Mark G's Avatar
Yeah, I was going to say the same thing. I've gotten lucky to get them off with a pliers before, but wasn't easy and chewed up the nut a lot. But that's only if it's not very tight. I made a socket from a piect of exhaust tubing, welder, etc. Best to just buy one for like $20 from roverparts. You won't just go into any store and get one. You could spend 1/2 day searching. Inspect your brakes too, and rotors prior to doing the job. Get the rotor turned or replaced if it needs it. That's THE best time to do your brakes if they are so-so.
Old Sep 28, 2010 | 10:47 AM
NiteTrain's Avatar
don't forget wheel bearing grease for packing bearings...as far as the socket I believe it's a 2-1/16 socket but I used a big pair of slip joint pilers.
Old Sep 28, 2010 | 05:41 PM
The LR rotors supposedly are not made to be turned.......
Rovers North has a rotor and pads kit for approx 100 bucks per axle that uses Mintex pads and ProLine rotors, I have those all around, can't beat the price as far as I am concerned. They have the socket for removing the hub nut and the lockwashers as well.
dillhole
Oct 30, 2016 04:43 PM
sickws6
Jun 25, 2012 02:26 AM
XxRoverAllOverxX
Oct 4, 2010 02:47 PM
rsandmeyer@cox.net
Apr 25, 2010 04:46 PM
Disco2Fever
Sep 24, 2008 09:26 AM
