Cannot shift out of park
Old Nov 30, 2011 | 10:49 AM
  #21
Danny Lee 97 Disco's Avatar
That says the pin was sticking. A solenoid moves the pin magnetically by means of an electrical field. If the pin was stuck, the magnetic field could overcome the physical binding condition.
I would spray it good with either WD40 or PB50 (new PB Blaster Spray Lube) to keep it working good.
Old Feb 18, 2013 | 02:06 PM
  #22
gman21's Avatar
I took my console apart and took the shifter apart and sniped the ren n black wires to the silanoid and tested it to a hot battery.and it workd ten out of ten times tested now im thinking im not geting fire to the silenoid any help ?
Old Aug 4, 2013 | 02:23 PM
  #23
highangle's Avatar
Default Discovery 1 Cannot shift out of park - fixed
Just had the same problem, loaded up ready for a day off and bam, no shifting.
Following everyone's advice (taillights worked, so not brake switch) disassembled to the solenoid. Tested solenoid circuit at the connector (8 wires or so, traced to the red/black (all black, no stripes) connectors) nothing. Tried red to ground, touched brakes and bam, closed circuit.
Ran hot to red on solenoid, black to ground and it worked every time. Short of chasing a ground wire through the loop, snipped black, connected to the shifter mount screws with a spade. Back in business!!!
Next time I'll remember to check the electrics before I dig all the way down to the part....pulled the solenoid out before I thought to check.
Thought of taking pictures just as I was buttoning it all up, so nothing to show. feel free to PM me if anyone has any questions.
Old Aug 7, 2013 | 10:45 AM
  #24
robertmirwin's Avatar
also check to makes sure your battery is good. that is a 12v switch and will not let you shift out of park unless it is getting over 12v. had the same problem in my rover ended up being a weak battery. truck would still start and everything work like it should but was only getting like 11.2v so it would not shift from park
good luck
Old Aug 25, 2014 | 08:39 PM
  #25
pedro_malo's Avatar
Any of you blokes involved in figuring this out up for a call to discuss? I have the same crazy problem.
Old Aug 18, 2017 | 12:07 PM
  #26
NewTotheroverlife's Avatar
I have a 99 discovery 2 dash says Neutral but shifter is in park
Old Aug 18, 2017 | 12:28 PM
  #27
Old Jun 3, 2018 | 02:25 PM
  #28
keoni004's Avatar
Thanks for the feedback everyone. This just happened to me this morning and the forum feedback helps. There's a great thread in the D2 section, and a write-up on Atlantic British (https://www.roverparts.com/TechTips/...ut_of_park.cfm)
- I started the truck, couldn't shift out of park while depressing the brake pedal.
- No brake lights when depressed.
- Checked the blue 15-amp fuse, intact.
- Pulled the brake light switch, the plunger had actually broken, and the red sleeve had separated from the black housing.
- Replaced the switch (top one of the two above the brake pedal), back on the road again.
The switch was a PITA to get back in...I ended up hooking the bottom lip of the switch in first, and then levered it upward until the top snapped into place with the metal bracket.
I tried to consolidate the part numbers, too. Hope this helps someone.
Atlantic British: "Switch - Brake Light With ABS", $89.95 https://www.roverparts.com/Parts/LR005794G
Amazon: "Standard Motor Products SLS259 Stoplight Switch", $13.68
https://smile.amazon.com/Standard-Mo...ype=automotive
Napa: "Stoplight Switch, Echlin Ignition, Part ECH SL811", $31.49
https://www.napaonline.com/en/p/ECHSL811?interchange=1
G Reeves
May 18, 2013 12:05 PM
Dan Wallace
Jul 30, 2012 03:51 PM
1gensrt
Apr 19, 2011 01:36 PM
discolucy
Oct 28, 2009 12:43 PM
dlkk
Jan 13, 2009 02:09 PM
