Check Engine bulb?
When I first bought this truck, the CEL was lit. I cleared the ***-load of codes and began the process of the 60k.
Fast forward a few months to present. The light has never come back on (not even when just turning key to "ON") since I cleared the codes that first time.
I went on my first real drive on friday. Still no light, but I figured I would get the reader out afterwards to see if anything popped up. Only thing is the TPS (P0123 I think it was?), verified bad by the live data which shows it at a constant 93.
Is this simply a fried bulb that needs to be replaced?
It is a little peanut bulb, your best bet is to take it to the autoparts store or dealer with you, the bulb I mean.
Or you can swap it with one that works, like the red "service engine soon" light.
That one is a non issue when it comes on, it will not trow a code for that one either, so just swap the bulbs, thats what I would do.
Pinky- Sorry to hear about but- I totally would not fix that. I would only rip that out to remove it. I can plug in my scanner if I want to see my CELs. FYI- on your way to the inspection, stop next door, clear your codes and have an inspection. I think you should be good for fifteen minutes- No? Good luck
Ah, its not an inspection problem as we dont have 'em in MN. I just wanted to know if it was a bulb issue or something worse.
Does the AntiLock bulb swap right in? I took my pump fuse out so I dont really need that.
Bulb reference. Courtesy of Rovers North.
Land Rover Discovery I Auxiliary Bulbs, Lens, Electrical Parts Available from RoversNorth.com
Classklown90
Aug 21, 2010 07:24 PM
miishmiish
Mar 8, 2006 12:31 AM
