check engine light on
Old Nov 2, 2011 | 09:12 PM
DIY73's Avatar
Default check engine light on
hi! i had the battery disconected due to the head gasket replacement.right after i start it the check engine light went.i don't need to read any code.just want it off.any ideas?
Old Nov 2, 2011 | 09:20 PM
If you don't have a code reader most auto parts stores will read for free. In some states they are not allowed to clear codes, and I suspect once the savage corporate attorneys look at it that might become a nationwide standard for various chains. But you might want to be sure about codes, after major engine work. Also, this depends on which year truck you have. What year?
Old Nov 2, 2011 | 09:31 PM
Without knowing what year your truck is we cant help you.
And the battery being unhooked has nothing to do with the check engine light coming on.
You have a problem and the code will help you figure out what it is.
Old Nov 3, 2011 | 11:17 AM
DIY73's Avatar
Default 98 disco
guys! thank's for reply.i have a 98 Disco.i found a code reader & clear that light .curious if its comming back. i'll let you know
Old Nov 3, 2011 | 12:33 PM
fishEH's Avatar
Did you at least read the code while you had it hooked up???
Old Nov 3, 2011 | 01:16 PM
Well, if you need to, stop at autoparts store and they can read it if it returns.
Old Nov 3, 2011 | 03:44 PM
psykokid's Avatar
A basic code reader is really a must for any obd2 disco.. I picked up a snazzy one from HF for 100 bucks with a coupon that will read live data and also log a minute of data. You can set it up to log manually or when a DTC is triggered..
Old Nov 3, 2011 | 08:19 PM
Fitzy250's Avatar
I bought an Ultra Guage and it will read codes and display up to 16 guages depending on which ones you pick i got it for the temp guage but you can also turn the check engine light off the best part only 80 bucks i would recomend doing a serch and checking them out
Old Nov 4, 2011 | 10:00 PM
ihscouts's Avatar
If you know it's nothing it will extinguish on it's own in a few drive cycles without having to reset.......
FlyingZebra34
Feb 22, 2014 05:39 PM
RoverZebra
Dec 8, 2012 04:27 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
