Climate Control Issue
Hello,
I recently took my dash out because of a water leak with the windshield, see https://landroverforums.com/forum/di...overy-i-50139/
I have had a issue since my A/C system had a leak (2010) the leak was a pipe in the back that had a crack in it. Ever since replacing that pipe, pulling a vacuum, and recharging the system the passenger side A/C is 10-15 degrees warmer than the drivers side! Since my dash board is out, I figure if I have a problem with something in the heater core area, now is the time to fix it!
Thanks
Thanks
Well, I would adjust for both to be closed fully at same location on dial. That's the only sync that counts, everything else is adjustable. But the make no difference, SWMBO will reach right over and adjust yours, needs her hand slapped I think...
I thought I was doing good to change the bulb....
I have both vents "closed" right now, yet the wires are two different lengths. The drivers is shorter than the passengers. Perhaps this is why?!
SWMBO will get a slap to the hands if she misses with my side, thats why we have "climate zones".
Green Blood
Dec 22, 2018 04:40 PM
Onyx Z32
May 2, 2013 09:22 AM
Vertigo RT
Sep 6, 2010 11:44 AM
