Clunking Noise drivers front wheel
Old Oct 23, 2018 | 09:31 PM
Crunkgringo's Avatar
That play looks normal to me. It won't move that much with the circlip in place.
Old Oct 23, 2018 | 09:56 PM
scsand's Avatar
hmm... ok.. so I guess I'll continue dismantling and see if something else comes up.
Old Oct 23, 2018 | 10:42 PM
Icannap1's Avatar
It looks like a worn out part #4 needs to be replaced there is to much play you can use adjustable slip joint pliers to remove the nut. also check the splines on the stub axle it may also be worn if so you can get a used set from one of the vendors here for cheap.
Old Oct 24, 2018 | 07:04 AM
WaltNYC's Avatar
Icannap1, #4 (the drive flange) is not installed in those videos.
I'd continue to check bearings, swivel ball grease (which you already have done), and front diff fluid as well.
The sound (clunk) began soon after work was done, correct? You've removed the possibility of caliper/pad issues. So I'd get a look at the bearings.
At the end of the day you might just have a worn CV joint but the coincidence with work being done leads me to doubt it.
Old Oct 24, 2018 | 08:03 AM
scsand's Avatar
bearing seems fine. when I spin the rotor no noises. clunking may have been there before..i'm not 100% sure... I'm leaning towards worn cv joint. I may need some help identifying that once I pull everything apart.. (sunday).. I'll check the splines on the axel stub, etc as well... thx everyone for input...
Old Oct 24, 2018 | 03:53 PM
Icannap1's Avatar
You're right Walt no flanges installed I missed that on the 2 videos.
archaeology_student
Jul 31, 2019 11:44 AM
gunsanroses91
Jun 3, 2015 05:13 AM
Externet
Sep 7, 2012 02:29 PM
hampshier32000
May 10, 2011 11:54 AM
lightfootboyd
Oct 16, 2007 04:40 AM
