Disco 1 AC issue
Old Sep 26, 2013 | 10:00 AM
binvanna's Avatar
Originally Posted by TOM R
Glad you found the problem, mine has a slow leak so we just refilled it again 2nd time in 2 weeks and added dye, any thoughts on what it probly is? I have rear a/c
driver side rear wheel well... the ac pipe is rubbed through just above the spring
get a new ac pipe, and put a protective sleeve on it before you install it... the pipe you need to replace goes from a connector just in front of the wheel well, to the ac condenser just behind the wheel well. It's an easy swap if you just take the wheel off.
Old Sep 27, 2013 | 08:37 AM
TOM R's Avatar
We actually repaired the pipe, now it leaks at the fitting at one end of the pipe, I didn't replace the o rings
It was not rubbed through, it was corroded through salt in rust belt baaad
Old Sep 30, 2013 | 10:49 AM
abran's Avatar
Default Got the switches out!
I just pulled some switches form a parts car. You need to take off the center louvre panel, then the switches can be pushed out form the back of the AC/Heater assembly.
Super easy once you dig in.
Attached Thumbnails Disco 1 AC issue-screen-shot-2013-09-29-11.15.35-am.jpg   Disco 1 AC issue-screen-shot-2013-09-30-8.46.43-am.jpg
Alex_M
Nov 17, 2014 07:34 AM
nate2k5
Jun 3, 2012 05:49 AM
Kingmarine
Feb 26, 2012 09:27 PM
tunernewb92
Oct 20, 2009 07:15 PM
dms98e
May 9, 2008 08:36 AM
