Disco 1 won't move in gear
#32
#33
#34
Well, I believe I have bad news. I couldn't get the inspection cover off without removing the exhaust pipe (something I don't have time to do now), and I was afraid of rounding off those 10mm bolts.
So, I took the drain plug back out with intentions of emptying the case, and I plugged the hole with a rag, while I inspected the plug magnet. I found about a zillion tiny metal particles sticking off of the plug magnet like hairs, plus quite a few 1 to 2mm sized chunks of brass-colored metal, to boot.
I cleaned the plug, put it back in, started and ran the truck for a minute or two, took the plug back out, and got the exact same thing.
Third time being the charm, I repeated the process, and got the really big pieces/chunks of metal. Again.
This, and the fact the high/low lever will not budge (even by whacking it with a hammer), has convinced me the TC has gone to the Happy Hunting Ground.
So, with heavy heart, I've decided to weigh my options of either, a), selling it for a boat anchor on Craigslist, or b), picking up a TC at a local yard (150+ USD is the going price here) and fixing it myself.
Never having done a TC before, can anyone give me an idea of how difficult this would be? I rebuilt several US auto transmissions and V-8 engines, so I have those skilz, but I'm not sure what's involved in a TC swap....can anyone give me a quick opinion/run-down?
Rob
Rob
#36
#37
Tom...my local yard has 4 of them (D1's), and I thought I'd go ahead and pull the inspection plate on any particular one that I settled on, just to be safe.
The 3 upper-most plate bolts are under the exhaust pipe; normally, a boxed end wench would go in the space, but as I was trying to remove those three, the heads started to round-off, so I stopped....I figure a socket would be the best means of removal, but right now, the pipe is in the way.
Rob
#38
Yeah, I downloaded a copy last year; I'm assuming it has a step-by-step process for removal? I was hoping to avoid having to pull the trans completely out of the truck....
Rob
Rob
#40
Pipe
Rob
Rob
Good luck
